Hi all,
Currently building a full chassis loom for my Almac (lotus 7ish style) and wondering what ring terminals everyone uses for earthing.
Mostly using 14 - 22 awg so likely to need multiple sizes in wire size and bolt size.
I assume non insulated is the best route but struggling to find anything that looks like it suits in NZ.
Thanks in advance
Craig
I like to use the ones with adhesive lined heat shrink that I get from Terminal Supply Company here in the US.
http://terminalsupplyco.com/Store/Default.aspx?CAT=HST010010&PCAT=114156#Categories
http://terminalsupplyco.com/Store/Default.aspx?CAT=HST020010&PCAT=114162#Categories
I'm looking for a multi wire o-ring solder + crimp terminal. I have those in my 2012 Camaro, but they have integrated screws and a hook and they were screwed into the chassis.
Maybe someone knows similar multi wire o-ring terminals with M10? :)
