Flasher unit
1236 Vistas
Hi guys, just wondering if anyone can recommend a flasher unit to use for my car (98 civic)? Im doing a full rewire, bussmann RTMR etc and following on from webinar 187 I need to use a 3 pin unit, and I'm not using LEDs so needs to be thermal switch type? I've been looking on Mouser RS etc all evening and can't seem to find what I'm after, if anyone had a link or PN that would be great.
Cheers
Since this is a normal automotive item, hopefully you can find something on here that would work for you:
https://www.amazon.co.uk/s?k=automotive+flasher&ref=nb_sb_noss_2
