Haltech Elite Fuel Economy Calculation? (mpg/kpl/etc.)
1083 Vistas
I have been trying to figure out if there is a way to calculate instantaneous fuel economy (in miles per gallon in my case) in the Elite 2500 ECU. The ECU has all of the info to perform the calculation, but I have yet to figure out how to set it up, if it is even possible. It is possible with a Holley Dominator, as a good friend of mine has set it up using advanced tables. Amy heln would be appreciated. Thanks.
