Holley Sniper V1 - Stalling on double downshift decel
291 Vistas
Ford Falcon - MANUAL TRANSMISSION
289 with mild cam and headers (timing not controlled by sniper, 17 degrees base, 34 total at wot)
No clutch switch or VSS input
Sniper V1
I am using V1.3 Build 50 - updated existing config from V1.1.25
On a “double down shift deceleration” when throttle is not touched between shifts it will stall, worse as everything heatsoaks.
Seems like after the first down shift idle fueling is not turning back on.
Attached is my config and datalog, stalling is at the end
I tried an advanced table for the IAC previously but it didn’t help
Fuel pressure 65psi
Checked for vac leaks
All 4 injectors are firing at idle
This software version does NOT have the ability to adjust decel fuel cut parameters
Any input would be appreciated!
.dlz datalog file
https://drive.google.com/file/d/1P6KYOZV4QKZGMnwl7FxNDXewxIDJ8zm4/view?usp=sharing
.dl datalog file
[size= 14.6667px; white-space-collapse: preserve]https://drive.google.com/file/d/1qbXEB02qccEhGuq6Bq-h4d2kyD5jMJRu/view?usp=sharing[/size]
Config info link
[url=https://drive.google.com/file/d/1QbpFA8YGyyEdUlrqASTDdmvxjWDAWWeO/view?usp=sharing]https://drive.google.com/file/d/1QbpFA8YGyyEdUlrqASTDdmvxjWDAWWeO/view?usp=sharing
Global config file link
[url=https://drive.google.com/file/d/1aA8GdA0vNjjf74PDGqMgB098lSMhI76X/view?usp=sharing]https://drive.google.com/file/d/1aA8GdA0vNjjf74PDGqMgB098lSMhI76X/view?usp=sharing
