Hello, i trying to find the way to linearize NTC sensor for oil temp chanel what is not on the list on a M130. I can't find the way to add resistance values at the table axis. Some idea to linearize 2 wires resistance sensors?
Select Manual Calibration, and use the Translation table. You will have to convert your resistance into voltage, using the voltage source and pullup resistors used.
Here is a spreadsheet I use to do the calculations. Perhaps it will help you.
What is the part number of the sensor?
