Injector Flow Rate and Deadtime.
760 Vistas
Hello! Can anyone, please, help me figure out the correct flow rate and deadtime for my Bosch 0280156372 injectors? I've searched the web and I find different values for flow everywere I look and as far as dead time values I didn't find anything.
Found some charts where they're rated at 150cc/min, found them for sale on different online shops with different specs every place, some rate them at 138.9 g/min some at 116.5 g/min, 150 g/min, I even found some 162 cc/min or 15.4 lb/hr.
Also, does N-Heptane have the same flow rate as Gasoline? Because all the flow rates that I found are done using N-Heptane as test fluid.
As you can guess, I'm very confused. Please help!
