Innovate LM2 Analog cable/pin data
4054 Vistas
hello Everyone
I got innovate LM2 AFR meter, anyone who knows the analog O/I pin data, the manual doesn't tell the exact pin numbering data, I just need to use the analog output to be use as analog volt input to the ecu.
Cheers!
G'day Leo.
I can see what you mean, I had a quick scan through the LM2 user manual here:
http://www.innovatemotorsports.com/support/manual/LM2_Manual.pdf
As far as I can see there isn't a pin-out for the connections on the bottom of the unit, but there is one for the cable itself. Have you still got the original analogue cable kicking around?
Hello Zac,
Thanks for the reply mate, I did not buy the whole LM2 AFR kit, reason why I don't have the 14 pin analog cable, there is a 14 pin sets of connection under the unit for analog out and in, two 8 pin for o2 sensors, one 10 pin for obd and a 4 pin for power supply, since I don't have the 14 pin analog cable, I can't use those 14 pin connections underneath the unit, if you got similar cable? if you have one please send me a picture please. thanks mate !
Bugger! Yeah, shame they don't have an actual pin-out. We've got one here, I'll find it and tone-out the cable for you after work.
Thanks heaps Zac I appreciate your help mate cheers!
G'day Leo. Had to hunt, but I found the cable. See the attached picture. They're all paired differential IO's, matching positive and negative terminals above and below one another. Hope this helps! :-).
Also, I suspect this is the connector you need if you were to make your own cable:
https://www.moddiy.com/products/Molex-43025%252d1400-Micro%252dFit-3.0mm-Pitch-Female-Housing-14%252dPin-Connector.html
Thanks a lot Zac your a legend cheers!
Leo
i know this is old thread but was wondering if any you guys have the pinout for the OBD2 cable.
