ls gen 3 6.0 swap on y61 nissan patrol
394 Vistas
Hi, I bought a Nissan Patrol y61 with a gen 3 6.0 swap with a P01 ECU the car previously had a magunson 1.9 supercharger. I dropped the supercharger and the engine internals are stock. I am going to use it this way for a while before getting the engine built and reinstalling the charger.
My question is the car has this set of injectors, 46lb/h Siemens Deka High Impedance (Mid Length) with EV6 / USCAR Connector – FI11354 (48mm).
I couldn't find the injector data any where any my MAF is deleted is there a way to tune this car without having to swap the injectors ?
