Hi
i have a maxxecu race extra been fitted
wide band sensors was not I have the harness and sensor can I just fit this and remove the original one as , this was a plug and play for 1.8 t Audi 8l .
car is having idle issues and cold start .
and it been set to open loop boost and open loop on ecu ? Be tool should be close loop ?
salut tu doit retirer lencien capteur et metre l enouveau en lsu 4 car le maxxecu ne gere pas la sonde bande etroite
demarrage a froid regarde si ta carte inition es a 10 pour commencer et aussi la table ve en dessous de 40 a O de MAP
