Raceme/MM3 Warp tune test
1309 Vistas
I have copied some of the values from a sample file and then used efi live calculator to slightly adjust the timing I would like for someone to look it over and tell me if it should be at least in a starting ball park. Also the Warp program can be quite a pain compared to most everything else out there.
16 Ram stock motor 150k miles daily driver pulls a camper once a month.
Link to Cals
Also wondering If anyone knows what in the raceme calibration makes the exhaust pressure senor PID always show 0? I do have the exhaust pres. sensor switch turned on.
Hey Joe,
Can you attach an efilive file instead? I cannot view race me files (delete program).
Nick
Nick doesn't your business sell custom Raceme tunes?
