Hi, I have an SR20DET I recently bought an Haltech Elite 750 and the Harness from Wiring Specialties, I've plugged everything in, the Car Cranks, I do Get RPM on the computer but I'm not getting Spark on the Coils, when I take out the CAS, and I Rotate it by Hand, it does some clicks, and I get RPM on the Computer. any Idea what could it be ?
Shakeel,
Does your harness include non stock coils that perhaps require different settings than a standard SR20DET?
The CAS itself is a point of issue for many as well, so it's possible it's not providing a signal that the ECU is accepting. Are you getting sync?
Haltech has a bunch of specific info on triggering errors here to help you narrow down the issue:
https://support.haltech.com/portal/en/kb/articles/trigger-elite
