Start Up Sequence - How is yours set up? - Haltech
311 Vistas
Hi all,
I'm struggling to understand how to set up the start sequence for my track car project, mainly the logic within the NSP.
I have a Haltech Nexus R3, Ic7 dash and Haltech CAN keypad.
I have a manual battery isolator that I have wired the 12V+ Low Current output and Ignition Switch input too also - hence when the battery isolator is turned on, the car is essentially past the accessories 'key' position and resting against the 'Ignition' position ready for a momentary input via a CAN keypad button press to start the car (that's my understanding).
I think it's related to setting up Generic Conditions/Inputs/Outputs to give then give a CAN keypad button control over what happens next but i can't seem to make sense of it.
If anyone could share examples of how they have set up theirs, including NSP logic, or just explain the steps or screenshots that would be greatly appreciated. Also happy to have my own understanding corrected if I'm off the mark.
Many Thanks,
Daryl
