VE calculation Rotary engine
86 Vistas
I couldnt find it anywhere.
how do you calculate the correct VE on a rotary engine, for example a 13b (1308cc) as the stokes per revolution are also completely different
would prefer if u make example in metric system as urs is really difficult for me to understand :)
You treat it like a 2.6L 4 cylinder 4 stroke/2 cylinder 2 stroke at 1.3L in a 720 degree crank cycle.
I googled rotary engine VE table and it has tons of information with pictures, explanations and so on...
