N/A LS Build 9000 RPM Help Needed
85 Vistas
Hey guys,
Building a high RPM LS (9000 RPM goal).
Specs so far:
  • LS3 block
  • 3.267” stroke, 6.300” rods
  • 58x crank (okay to switch to 24x)
  • Using E38 ECU for now, maybe Haltech/MoTeC later
Need help with:
  1. Timing set – go single or double roller?
  2. Cam gear – better to use 4x (front sensor) or switch to 1x (rear)?
Let me know what works best for high RPM setups. Thanks
