Quick Lambda
Módulo relevante: Cómo usar M1 Tune > Función Lambda Rápida
553 Vistas
I am looking to tune a jetski using the Quick Lambda and / or the Lambda was function.
Is it possible to run the jetski unconnected to the laptop and use recorded data for the Quick Lambda Function or does the ECU need to be connected at all times to use the recorded data?
Thanks in advance
Hi Colin,
You can manually use the quick lambda function with logged data using i2 and Tune 1.4. With Tune 1.5 and Pro logging enabled, you can replay logged data from i2 in M1 Tune and work on the configuration the same way as if you had had the laptop connected. You do need to ensure that you have all of the relevant channels logged to be able to do this.
Thanks Stephen,
Appreciate your help
