Sard fuel pressure regulator limits
1718 Vistas
Can anyone confirm the flow limit of a genuine SARD@ idle @3bar fuel pressure?
Also if I'm going to a twin intank pump setup is there an issue with the pumps being different sizes when they are both feeding the same rail? I want to keep the pumps as small as possible. Fuel requirement is 470LPH @5.5bar
current fuel set up.
walbro 400lph intank--5/16 feed line--Rail--2200cc injectors--Sard FPR--5/16 return line--tank
Proposed set up
1xwalbro 400lph intank--5/16 feed line
AND Both feeding rail--2200cc injectors--3/8line to Sard FPR--an8 to 12.7mm hardline back to tank
1xwalbro 225lph intank--5/16 feed line
The Sard regulator is too small for what you're wanting to do. The issue is that you're restricted to the 1/8" inlet and outlet which will restrict flow. In rough terms these regs are good to about 500 hp on pump gas. It would work with a single Walbro 255 but not much more. I'd suggest stepping up to something that will support -8 AN fittings for your application.
I also wouldn't suggest fitting two high pressure pumps that are different flow ratings.
