the exact meaning of stroke
Módulo relevante: Principios fundamentales del motor > Principios del motor > Eficiencia volumétrica
165 Vistas
just only to make sure that I understand the real length of the stroke .
the stroke is the distance between the TDC and BDC or the distance from the BDC to the head of the spark plug
which one is the right understanding for the meaning of the stroke ?
thank you and please excuse my English language
✅ The correct definition of stroke:
The stroke is the distance the piston travels from:
- TDC (Top Dead Center) → the highest point the piston reaches
to
- BDC (Bottom Dead Center) → the lowest point the piston reaches
It is not measured to the spark plug or cylinder head.
It’s only the movement range of the piston inside the cylinder.
So:
- Stroke = distance between TDC and BDC
Yes, that's correct.
