ECU master club isolator
1287 Vistas
Hi guys, I have a bought a ECU master club isolator with the Deutsch plug, is it possible to wire this as stand alone without canbus or have I bought the wrong thing? Basically I'm not running a pdu so wanting it to cut the power as it should but the instructions show can h can l
Yes it can be standalone. You run the switches as shown in the installation manual and using light client you can disable the CAN error led warning. You will still need a USBtoCAN connection to program it
