Lofted flange
Modelado 3D y CAD para deportes de motor
Módulo relevante: Fundamentos del modelado de chapa metálica > Bridas
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
1349 Vistas
Hello, I just completed the "Flanges" module and everything went smoothly as I was following along in fusion 360 version (19045.3693) (up to date currently) when trying to complete the lofted flange demo on my end the feature would generate but would not allow me to complete it. The "ok " selection was greyed out preventing me from generating the model. I followed along to a T and even tried new drawings all settings exactly how the module was modeled with no luck . I don't understand what I am missing or if there is a glitch within fusion 360 or simply not available to me on the " personal use " version. Thanks and have a great day
Hi Julian,
Just had a bit of a look into this, you can definitely use the lofted flange function in the "personal use version" I just checked on our videographers computer to make sure. Also if you can't use a function it'll usually have the little blue "plug" icon for extensions over it, so it'll be more clear.
There has been some small changes around this module, with the new version, as there is now a rip tool, but he lofted flange tool remains unchanged.
I've just followed along with the module and everything seems to work fine from my end.
Could you send some photos or screen recordings so I can try spot the issue?
