Over constrained sketch
Modelado 3D y CAD para deportes de motor
Módulo relevante: Fundamentos del modelado de sólidos > Boceto 2D
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
1191 Vistas
Why is it that when I try to dimension a circle, fusion says that it is an over constrained sketch, and wants to create a driven dimension instead?
I'm new to fusion and cad, but this must mean that the circle already is fully defined. the sketch(circle) will be black instead of blue once fully defined.
you are trying to define a circle that's already defined. does it show a number next to the circle? when editing sketch? if so that's the dimension for it already.
hope this helped?? can try add screenshot if not.
you can double click that circle diameter number and change it to what's needed.
Ashley is correct, but upload a screenshot if you want and we can give you a specific reason.
