Reverse Engineering Engine mounts as sheet metal bodies (E36 M6x swap)
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
184 Vistas
So I have two Engine mounts that I have to reverse engineer for my e36 swap. I could use the engine mounts I've scanned but they're really heavy and ugly, I wanna make them a bit lighter and a bit more presentable. I'm having trouble with designing them to be easily manufacturable. I've figured out how to cut them so they fit togther, but I'm still struggling in making some "locating" geometry so I can just snap everything in place and weld them together. Any ideas would be appriciated. I'll also post my full fusion project so you guys can take a look at my workflow.
  • E36-M6x-Swap-Mount-1-v2.stl
  • E36-M6x-Swap-Mount-2-v2.stl
  • Engine-Mounts-v2.f3z
