E46 Coupe CoG Height
Diseño y optimización del sistema de frenos
Discusión y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos
1565 Vistas
Don't have the gear to measure the CoG Height for my E46 Coupe. Does anyone have a sane/safe value I can put in for the brake bias calculator?
Google AI says 21.6 inches. I was going to guess between 20 and 24 inches when I decided to try googling "E46 Center of Gravity height"
@david thanks for the reply. I did google around before posting and got zero definitive results. Can you post the links that your google AI search used as references?
It probably came from an NHTSA report that supposedly lists the CoG height of some production vehicles.
The last posting in this thread has a guy offering to help you find the info:
https://www.bimmerfest.com/threads/center-of-gravity-height.1294975/
