Discusión y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos
Good afternoon all!
This is my first post here and starting it with a big question to you all.
Am currently using a KPRO V4 and have just installed the IC7 Haltech Dash display. Connected everything as it should and insructed and connected the CANBUS (CanH/CanL) from the ECU to the Dash although am not getting any RPMS, Speed etc.
I checked both the ECU and dash and found that the IC7 has it's own protocols, the ECU also has it's own protocols for output. I have tried the KPRO Motec output protocol to the IC7 Motec M1/100 Protocol but with no success.
I have not yet tried the other available protocols from both as I have to return to my tuner to be able to configure anything.. Can anyone shed some light on this so maybe these two can communicate and go to my tuner with a solution if possible?
Thank you in advance!
Isaac,
That's very thoughtful of you. I haven't done that combo so I don't know the solution offhand, but on the dash side there's significant flexibility so I'm fairly confident there will be a solution.
In the meantime, make sure everything on the CAN bus is operating at the same speed i.e. 1MB or 500k. If they aren't you won't have comms.
Hi guys just a quick update!
Since IC7 was pushed to the NSP software, it now connects to the KPRO ECU and finally happy :)
