Longitudinal Load Transfer Pad Force Requirement
Diseño y optimización del sistema de frenos
Módulo relevante: Diseño del sistema de frenos > Discos, pinzas y pastillas
Discusión y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos
1296 Vistas
How did you find the pad force requirement by only having the effective diameter, the effective radius, the target brake torque, and the pad's coefficient of friction? I am confused as to how you were able to get 26,388N.
Torque = the friction force from the pad X distance from the centre of rotation (the effective radius)
Rearrange that to Friction force = Torque/Effective radius
The friction force = Normal force on the pad X Pad COF
Rearrange to Normal Force = Friction force/COF
That normal force is the pad force requirement
