Torque limiter
Diseño y optimización del sistema de frenos
Discusión y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos
2679 Vistas
Hi andre
What will happen If I make changes to fuel and ignition maps and don't do any thing with torque limiter and wish map in the oem ecu ? And what is the values in torque limiter map ?
Thank you
It depends on the ECU, but the torque limiter will most likely close the throttle if the calculated torque exceeds the limit.
I'M working on bosche me744.
Thank u for replay. Do u know the acceleration pedal sensitive 3d shape looks like ?
