AFR map for high Revving
Entendiendo AFR
2028 Vistas
Hello,
In the Fifth module (The AFR Target MAP) it is shown for engines with max. rpm of about 7000 RPM, but how does it work for high revving engines that has rev limit of 14,000 rpm?
It just extends to the right to the RPM limit of the engine.
