afr target table
Entendiendo AFR
2353 Vistas
this is only applicable when the wideband is wired into the ecu right?
If it is a VE fuel model with injector data input the target AFR table is still used by the ecu without closed loop feedback.
How it actually works is specific to the ECU.
