Air Fuel Ratio
Entendiendo AFR
2855 Vistas
how do i get my series6 rotary to idle an cruise at 14.7 afr? im running single turbo T04z an a power fc ecu.
What port work, Injector sizes, and ecu are you running?
Your question is a little broad. Are you meaning that if you get the AFR to 14.7:1, the engine won't run well? I'd also like to know if the engine is stock or ported.
