Attached download for fuel AFR's
Entendiendo AFR
3949 Vistas
While using the course I noticed there wasnt a link for the download, assume this is just a crossover process?
Thanks guys keep the good work up
Here you are, while this is simply one I made a while back, the figures are still the same. Enjoy!
  • Lambda-to-AFR-conversion.pdf
I calculated a spreadsheet this afternoon after I posted in the other threads. It is a little bit more involved (it has petrol, flexfuel, diesel, methanol, and LPG), if anyone finds mistakes please feel free to let me know and I'll fix them up.
I will probably rewrite it in a proper chart format to make it easier to read.
  • Lambda-AFR.pdf
