Clarification on the Air Temperature Compensation Table
Entendiendo AFR
Módulo relevante: Compensaciones de combustible > Compensación de la temperatura del aire
702 Vistas
In the lecture I understood that 20 degrees celsius is standard conditions and to fill that point with zeros. In the example table however the zero degree point is filled with zeros and the 20 degree point is filled with -5%. I am confused and hope someone can explain to me what I am missing.
