Compensation Questions.
Entendiendo AFR
1664 Vistas
So adjusting the main fuel maps and ignition maps won't be enough? I would need to tune the compensation tables as well? How do I get into the compensation tables? If I tuned the complete fuel and ignition map the car wouldn't run on the map that I just tuned? It would use the compensation tables as temp changes and load changes? Wouldn't the main fuel and ignition tables cover the load compensation?
the compensation tables are for things like air temp and water temp correction ac on and off thy all need checking to maintain the desired afr
