Controlling a DI engine using aftermarket ECU
Entendiendo AFR
7745 Vistas
I've just seen that Link have released a GDI orientated ECU on the G4+ platform - the G4+ Force. http://www.linkecu.com/products/wirein-ecus/g4-force-gdi/
Looks like it only has 4 x injector / ignition outputs at this time, so limited for larger motors but I am sure they will expand on this in time.
Has anyone got any experience with this on a GDI motor?
Cheers
Alex
I have a Force GDI on the bench ready to install , its my first so i am excited to see the results although apprehensive at the same time , i will post results etc as i go on here .
Cheers Keith.
Cheers Keith.
It will be great to see your feedback Keith.
What motor are you going to be running with it?
