Cycling AFR for emmissions
Entendiendo AFR
Módulo relevante: Cómo afecta el AFR al motor > Efecto del AFR en las emisiones
1226 Vistas
How would I implement cycling the afr to ensure emmissions complicity
k20a2 turbo
fuel tech ft550
I don't understand the intent of the question?
Do you mean how would you tune the vehicle to pass emissions? First thing would be to check if you need the/a catalytic converter in the system, which is a virtual certainty, the next thing would be to check exactly what the WoF emissions test proceedure is and do what is required to match it.
That engine doesn't do what you're talking about in stock form, so I'd focus on other areas of calibration optimization, such as ensuring lambda 1 is maintained until component protection is required at higher loads.
