Desert climate
Entendiendo AFR
2137 Vistas
In the Middle East in the summer the wither is.very hot and the temperature reached 50C sometime do we need to make the AFR more retcher ?
As air temp increase oxygen density decreases so we in fact need to remove fuel at a rate of around 2% per 10 degree change.
Check out these 2 webinars which Might help with air temp correction understanding
https://www.hpacademy.com/previous-webinars/075-charge-temperature-compensation-link-g4/
https://www.hpacademy.com/previous-webinars/074-intake-air-temperature-correction-haltech-elite-2500/
