effect of afr on power
Entendiendo AFR
2037 Vistas
can a similar scenario be done for a boosted and nitrous engine showing the effect of afr on power for each scenario, within the safe limits of the afr , I 'll most appreciate these learning outcome & takeaways
Yes, the situation is essentially identical on forced induction engines. Of course we are more at risk of doing damage with an FI engine if we run it lean so some caution is required.
