Exhaust Gas temp (EGT)
Entendiendo AFR
2070 Vistas
Hi all in forum,
I am newbie in tuning world.
My question is :
Is EGT showed in tuning software? As I see in course video its screen comes from dyno. Thankw
EGT (Exhaust gas temperature) needs the correct temperature sender units to be fitted and connected, some dyno's have these as part of their diagnostic equipment and can read directly from them. it may be possible they're connected to the ECU, and the dyno' is taking the values from there?
