GM 6L80 Transmission Connector ID
Entendiendo AFR
3257 Vistas
I'm not sure if this is the right place to post this but....
I am trying to identify a connector used for the internal mode switch (sliding switch that indicates the position of the manual valve) on a GM 6L80E transmission. It is a pull to seat, unsealed, 6-socket connector with Delphi stamped on it.
I've searched Mouser, Digikey, Eficonnection, and Delphi/Aptiv's website and have had no luck.
Any help would be appreciated.
