IAT Correction In Injector Pulse Width
Entendiendo AFR
Módulo relevante: Compensaciones de combustible > Compensación de la temperatura del aire
178 Vistas
Hi! I have a standalone ECM from Thailand I'm using on a Dual Sport Motorcycle. The IAT correction is based on injector pulse width, not percentage. IE: +- 10 units and each unit is 0.1ms. How would one correct this in a percentage? Would it be based on the average injector pulse width through out the table? Any help would be greatly appreciated.
