Inovate LM2 vs RomRider
Entendiendo AFR
1431 Vistas
Hi guys, I have an innovate LM2 and would like to plug it straight into the RR logger, I know it is possible with some cables. Any1 have any pictures of these cables or some link? I just wanna have AFR wideband data on my loggs.
you need to use this cable - https://www.innovatemotorsports.com/program-cable-mtx-series-gauges-lm-2-lc-2-scg-1-psb-1-and-psn-1.html - and then get an adapter for that to USB. I believe the connector is called a ' serial port'. it looks like a VGA cable but it's not. I went to my local computer store for the adapter
