Lambda scale
Entendiendo AFR
1969 Vistas
Hi
Hello
There is a lambda scale
And
Lambda Target on the Pc
From where does the lambda comes on the screen
Is the wide band meter connected to the ecu?
Hello
Yes the wideband is connected to the ECU and the far target is entered by the tuner to suit what he/she wants as the target
Regards Ross
