Lambda Targets and Engine Pressure Ratio
Entendiendo AFR
1650 Vistas
Hi Guys,
I'm having a play around with road tuning my 98 WRX using engine pressure ratio as the fuel load axis.
I'm running a Haltech 1500 Elite with MAP and EMAP sensors.
How are you mapping out a target lambda table using EPR?
If it's based off the 'Estimated Map' targets, then I assume my targets would be very lean, as I wouldn't see parts of the table with richer lambda targets now.
Or is this calculated into the Emap/Imap ?
Thanks guys. Hoping someone smarter than me can help explain or clarify.
I wouldn't map lambda target based on that ratio. I'd run it on engine load (IMAP).
