Lamda
Entendiendo AFR
3104 Vistas
is it possible to tune a car with the factory lamda senor, for example a 2002 subaru wrx, is the oem lamda sufficient or is it necessary to have a wide band
The stock Subaru does display as a wideband value but I always use an external wideband as the OE one is very limited in range.
