Methanol afr target on N/A engine's.
Entendiendo AFR
3459 Vistas
Hi Andre,
Could you please advise about the afr target on methanol for N/A engine's?
I generally will aim for around 0.75-0.80 lambda for a N/A engine as a starting point and then test to see how the engine responds as I change the fuel delivery.
Many thanks Andre.
