problem after decceleration
Entendiendo AFR
1896 Vistas
hi,
when I am in decceleration and than I press the gas my mixture became lean to 1-2 sec and than it became to be good. in this time the engine get blow. how can Ifix this issue?
thanks
hi Tomer, I'm not sure that I understand exactly what went wrong here. It sounds like you're describing an accel enrichment issue but this certainly wouldn't result in engine failure. Can you give some more information around this/
