RIFE Sensor Block Reliability
Entendiendo AFR
4082 Vistas
Hello all,
Recently came across this new remote sensor block from RIFE. It seems like a very clean/sleek setup for remote mounting pressure sensors. All the sensors can be wired with just one single connector and with the block being mounted remotely it will be very easy to use rubber mounts to isolate from vibrations as well.
I am interested in running this setup for Oil pressure, fuel pressure and maybe EMAP. My only concern is regarding reliability of these sensors, In my research there is very little information of people running it so real world exposure seems limited at the moment.
Is anyone here running these?
https://rifesensors.com/product/triple-pressure-sensors/
