Stock "Power Enrichment EQ Ratio (Gas)" values changes drastically between RPM
Entendiendo AFR
3558 Vistas
Hi,
I'm working in my first reflash tuning of my car (Camaro 2017 V6 3.6L). I'm applying the knowledge acquired in the course to do the "Step 3 - Configure Base Tune File". When I analyzed the values of the stock Power Enrichment EQ Ratio (Gas) table, I noted that the values defined in the table constantly change (up and down) between RPMs drastically. My question is:
Is this a normal behavior in stock Power Enrichment EQ Ratio (Gas) values? In the courses, I don't remember to saw something like this (always the values form a smooth 3D shape of the table)
The values in my stock Power Enrichment EQ Ratio (Gas) table are as follow:
RPM Values
0 1.175
256 1.175
512 1.175
768 1.175
1024 1.175
1280 1.175
1536 1.184
1792 1.184
2048 1.184
2304 1.184
2560 1.180
2816 1.170
3072 1.167
3328 1.180
3584 1.180
3840 1.154
4096 1.142
4352 1.128
4608 1.115
4864 1.108
5120 1.119
5376 1.129
5632 1.139
5888 1.143
6144 1.146
6400 1.151
6656 1.177
6912 1.192
7168 1.192
7424 1.192
7680 1.192
7936 1.192
8192 1.192
Sincerely,
Luis Meléndez
I'm missing the "drastic" changes -- the overall change is less than 10% across the RPM range. Looks like it leans out near what I imagine is the torque peak (4864).
Thanks very much, now I see it what you said, there is no drastic changes. Maybe I got impress by the graph.
