Target Lambda map sanity check please
Entendiendo AFR
1917 Vistas
I am wondering if I could get a look at my target lambda map just to see if there is anything I may have overlooked or not caught my self.
My Combo is a 3300lbs mustang.
SBF 347 CID w/ GT4088R turbo/ 160-170 KPA max
9:1 compression
Forged pistons/rod/crank
AFR 185CC heads
HYD Roller Camshaft 226/226 duration @ .50 / .544 I/E lift
PUMP gas 0% ethanol
If there is any extra information that is needed please let me know. I greatly appreciate the help!
try this link to what i would suggest for your combo
https://www.dropbox.com/s/c3xsqqvk38ys0xc/Screenshot%202021-07-16%2021.48.49.png?dl=0
Regards Ross
