Wideband sensor adapter
Entendiendo AFR
2208 Vistas
Hi guys, is it ok to use an adapter to fit the 18mm sensor into a 12mm exhaust bung? sensor wont be in the gas flow but will it still register ok?
I have used one of the innovate swivel ones in a jet ski that only had a 12mm hole in the water jacket, it seemed to work ok. I would only do it as the last resort but better than nothing.
