WOT @ 2000rpm
Entendiendo AFR
1568 Vistas
How do you maintain 2000rpm while WOT and not accelerating to Rev Limiter ?
is it the dyno limiting it?
That is correct - dyno is controling the Load.
As Shoto said - but not all dyno's can do this, the more common inertia type cannot.
Thank you Shota!
I asked that question way to quickly :)
20 minutes later I learned about load baring dyno's.
