Better than expected phone scanning results
Escaneo 3D práctico
Discusión y preguntas relacionadas con el curso Escaneo 3D Práctico
305 Vistas
Hey all-
First off, love the site and courses, and podcasts, and everything HP Academy! I'm starting a custom motorcycle build, and needed to do some 3D scanning. Not knowing how much I'd need one in the future, was keen to see what results I could get from my phone and be able to put the money saved towards parts for the project. Bottom line up front, I'd say significantly better than expected results. While not to the level of an actual 3D scanner, for what I need- really just a rough framework to then add solid parametric bits into to use, I'd say it's working great. Accuracy is also better than expected. If people are interested, I'd be more than happy to make a post describing how I've figured out how to optimize a phone for getting some pretty decent 3D scan results. Pictures are of an engine scan i did, zoomed in on the intake ports, and a rear brake caliper for the motorcycle.
Let me know y'alls thoughts!
